Need help on model builder to create a geoprocessing tool
1295
04-17-2014 10:23 AM
JieGao
Basically I want to create a process as following: step 1) use one line feature class and one point feature class (both in NAD 83) to create a coverage. step 2) project the arc of the coverage by US_Continuous_Equidisatnt_Conic and output a shapefile. Step 3) do the geometry computing to calculate the shape length in miles. Step 4) import the shapefile into ArcSDE geodatabase.
Pls help and thanks in advance.
Jeff
JieGao
To be a little more specific,  something I can not figure out on 2), 3) and 4):
for 2) how I can use one of the component (arc) of the coverage before it is created as the input to Project tool ?
for 3) Can I automate the shape geometry computing in the process ?
for 4) How to load a local shapefile to a geodatabase automatically in the process ?
Thanks again.
Jeff
JieGao
Done, it turned out it is a quite easy job by a couple of lines of arcpy script, but not by Model Builder in my first attempt.
