Near Tool
7652
23
01-10-2012 10:37 AM
ABDALLAMOHAMED
Hello. I used Near tool in ArcMap 10 to calculate the near distnace and I got some fields with zeros value. Then I used the same layer in ArcMap 9.3, and I got near distance field without zeros values. I couldn't figure out the reason for that.Any hint.Appreciate. Thanks1
DanLee
by Esri Regular Contributor
I still don't see it. You can try to email it to me:  [email protected]
Thansk.
ABDALLAMOHAMED
I just sent it to you email..
Thanks!
DanLee
Thanks and I received the jpg image.
These touching cases are very much of the effect of raster/grid to vector/polygon conversion. You may consider the following options:
1. There is an Aggregate Polygons tool (Cartography - Generalization in ArcGIS 10; previously in Data Management - Generalization). You can try a small distance and see if the touching polygons become connected.
2. Or, if you want each group of touching polygons to merge into a new polygon, you can use the Buffer tool with a VERY small buffer distance (0.2 meters?). The resulting shape will be slightly enlarged and the corners become round, but the touching polygons will be connected with a small "width".
3. If you want the touching polygons to become disconnected, you can use the Buffer tool with a VERY small negative buffer distance (-0.2 meters?). Each resulting shape will be slightly smaller.
You can actually use the zero near_dist to select the touching polygons and apply one of the above ways to them only. Hope the slight gain or loss in shape_area is acceptable.
Hope this helps.
ABDALLAMOHAMED
Let me try them and let you know.
Thanks a lot..
ABDALLAMOHAMED
Dan..None of the above gave me the required result..I couldn't get the touching polygon to disconnect or aggregated in one polygon..Any hint? appreciated.
DanLee
The buffer approach should work. Did you zoom in to a touching spot to see?
Otherwise, can you share a small sample data, as shown in the image you sent me? You are using ArcGIS 10 with an ArcInfo license, correct?
ABDALLAMOHAMED
The buffer didn't work, because when I run the Near tool still getting zeros distance. Yes I'm using ArcMap 10.. I selected near distance with zero values and i will try to send you the layer in your email..
Thanks!
ABDALLAMOHAMED
I just sent you sample data in your email..Let me know if you receive it..
Thanks..
DanLee
No, I have not received your data. Did you send it to [email protected]? Did you get a return error? Try to send me an email without data first.
ABDALLAMOHAMED
I just sent you the whole shapefile in three different emails.. Because of my limit, I couldn't it in one email..I hope you have recieved it..please let me know..
Thanks!
