ModelBuilder: Setting Current Workspace from Input Variables
3436
09-03-2012 03:49 PM
DarrochKaye
I have a custom model which uses three tools and data from a variety of different geodatabases, however all the input data is from the same Feature Dataset.
Is there a way to set - without creating a variable - the current workspace as the same location as the input data?
DK
DarrochKaye
I found what I was looking for. in ModelBuilder, Insert > Create Variable... > Workspace, set it as a Model Parameter so now I can specify my workspace when adding inputs etc.
Thanks for your help.
DK
JonathanQuinn
Esri Notable Contributor
You can set current and scratch workspaces for individual models if you go to Model > Model Properties > Environments, check Workspace and then click Values.  Is that what you're looking for?  If not, I think you'll have to use a variable and inline substitution, as you'll need the workspace to be dynamic, based on where the inputs are coming from.
DarrochKaye
DK
