[ATTACH=CONFIG]23365[/ATTACH]
Hello All, I understand the limitations of ModelBuilder and adding to the Display when running outside the modelbuilder interface. In ArcGIS 10.0 my model uses in memory for everything except the elevation clip, percent rise, and slope. I am using inline-variables so the user only has to specify one output location for these three outputs. Is there a way to add to display using the inline variable one parameter method? Or is the only option removing the output workspace and making each a parameter? I understand the derived option and using python, I am actually using this in a separate model where I have to hard code values but wanted to use out of the box options.
On a related note. Is there a way to change the output data type within the model? As of now my outputs default to raster datasets or a combination of other things, is there a way to change this? When I open the output properties the option is grayed out.
Thank you for any help.
