Modelbuilder Help - Multiple inputs with different buffer values
1661
10-27-2010 06:32 AM
MikeWarner
Hello,
I'm having some trouble using modelbuilder to create a generic model that will do the following:
1.) Buffer multiple inputs (sometimes I have 5 inputs other times I have 10), each with a different buffer distance.
2.)  The buffer outputs are then merged together [to create buffer_merge.shp].
3.)  buffer_merge.shp is then merged with another input dataset [to create buffer_merge2.shp]
4.)  buffer_merge2.shp is then dissolved to create a single output layer named final_output.shp.
The model must be generic because, like I mentioned, the number of inputs and buffer distances change with each project.
To me this seems to be a fairly simple process but I can't seem to find a way to make it work.
Any ideas?
LornaMurison
What happens when you set the buffer input as a list?
MikeWarner
Lady_Jane,
If I set the buffer input as a list, the final output will be multiple outputs instead of just one.
For example, if I set it as a list and add 5 buffer inputs to my model, I end up with 5 outputs instead of the one, condensed output that I'm looking for.
LornaMurison
In that case, what does the first merge do?  Does it just merge the first buffer output with nothing?
When you change the buffer to a list, the first merge automatically changes to a list as well, right?
If so, can you change it back?
I feel like I've had this problem before I just can't remember how/if I solved it.
