Model differences in arcmap and arcgis
1022
05-26-2022 11:58 PM
KamilZoja
Hi! I made two same models in arcgispro and arcmap. I used iteration and only models tools. And I don't see any difference between these tools in both programs. Is there a difference? What to look for ?
Thank you for your help
DanPatterson
They should both produce the same results.  What differences are you looking for?
... sort of retired...
Nicole_Ueberschär
If you see different results, you might want to check the environment settings.
