Model Builder: Selecting multiple input files
10033
11-06-2013 10:01 AM
JaiKanth
I'm trying to use model builder to clip multiple rasters existing in Tiff format using a polygon extent. All 167 rasters are in a single folder on my hardrive. I created a list of the files as an excel file, indicating their full path. I then created an input variable in model builder as 'raster data layer' and selected 'A list of values' in properties. I opened the raster layer and tried to use 'Insert values from a table' to select all 167 files. This does not work and nothing gets added.
Am I doing something wrong? I tried the same using the list saved as CSV and Text files, but neither works. I'm also unable to copy the entire list and paste it into the datafield. I tried changing the variable type to 'Raster Dataset', but that doesn't work either.
Any help will be appreciated,
PS: I'm attaching the excel file containing the list of input files
XanderBakker
Esri Esteemed Contributor
You could use "Iterate Rasters (ModelBuilder)". Some more explanation can be found in this topic: "Examples of using iterators in ModelBuilder (Iterate Rasters)".
Also "A quick tour of using iterators" may be interesting.
Kind regards,
Xander
