Model Builder - Select, Select by Attribute, Calculate Field, and Coded Domains
2681
06-10-2014 04:21 AM
KathrynTucker
Two issues:
1) I'm trying to build a model that will take the table of a feature class and replace certain values in the same feature class. Example:
I have [field] with values (coded domains) of -1, 1, 2, 3, 4, X. Every time the coded domain is -1, I want to replace it with X.
There are ~15 fields that I want to do this with. Currently I am using Select Layer By Attribute, however this seems to mean that I have to have the layer in the .mxd to use the tool, and I would ideally like to run it from catalog. If I switch to using Select then I get a new feature class of my selection which will not work because in the end I need the whole table (or maybe there is a way it will work that I'm just not aware of yet).
Is there another tool to use, or a code block that I can tweak (there has to be...) in the Calculate field tool to select the records I want to change? I'm pretty decent with programming logic, but syntax is another issue entirely.
2) I have a coded domain value of 001, stored as text. I want to create a variable paramater for the model where the input will be exactly 001 and this will be used to calculate the field value. The problem is that every way that I do this the field updates to 1... unless I enclose 001 in double quotes. I was hoping to use the variable for other calculations where the quotes are not neccessary, and it would be best if I didn't need to rely on the user to read instructions about putting this parameter in double quotes (plenty of headaches could be avoided). Any way to do this??
markdenil
You could use CalculateField_management  for the first problem
using a code block that tests the existing value
and if it is -1, change it to X
and otherwise leave it alone.
With 15 fields to test, an update cursor with a similar test may be advisable.
for the second problem, you can accept the input as a string
as (for example: 1, 01 or 001) and use zfill(3) to pad out the entered string with zeros.
Now, whenever you want to use it as a number just convert it to an integer
int("001") returns 1
Integers don't have leading zeros, so they get stripped off
and however the user entered the string (for example, again: 1, 01 or 001)
the string gets padded to "001"
