Hi all,
I'm having trouble getting my model to work after I changed a few things and now I'm not sure what it might be.
What I have is a model that allows the user to select parcels of interest and run statistics of the area using the Zonal Statistics as Table tool.
[ATTACH=CONFIG]27650[/ATTACH]
However, I keep getting this error:
[ATTACH=CONFIG]27648[/ATTACH]
Which is described as follows:
[ATTACH=CONFIG]27649[/ATTACH]
I'm not sure but I think the problem has to do with the first option; where no statistic is performed for whatever reason.
Can anyone think of a reason why? Is the select by location not working after I changed the feature and selection layer (which in my case are the exact same shapefile)??
Any thoughts?!!
