Batch Import .e00 Files (w/in Directory/Sub-Directory) python script - ArcGIS 10.2
3607
09-20-2013 01:39 PM
JeremyLake1
Please Help...
Does anyone have a Python Script file to "Batch Import .e00 Files (w/in Directory/Sub-Directory) python script" for ArcGIS for Desktop 10.2, or can some one help me edit the importe00.py script which is included w/ ArcGIS for Desktop 10.2 (Code listed Below)?
I am attempting to create a .py file that will ask the user to select a "input directory" for the .e00 files, that will also search all sub-directories; then ask the user to select an "output directory" for the Coverage files.
I'm am extremely new to Python Scripting and really need help...
ESRI's importe00.py:
Tool Name:     ImportFromE00
Source Name:   importe00.py
Version:       ArcGIS 10.0
Author:        Environmental Systems Research Institute Inc.
Required Argumuments:  An input interchange file (.e00)
                        An output directory (where to put the output)
                        An output name (what to call the output)
Description:   Imports the contents of an ArcInfo interchange file
Notes:
- This script wraps ARCGISHOME/bin/import71.exe
- The executable only works on Windows with Desktop.
import arcpy, os, subprocess
#Convert the directory portion of a path string to short filename style
# Note that it is still possible for the name to be too long or to
# have some character in it that is not supported by workstation.
def getShortName(long_path):
    (long_dir, long_name) = os.path.split(long_path)
    for_cmd = 'for %I in ("' + long_dir + '") do echo %~sI'
    p = subprocess.Popen(for_cmd, shell=True, stdout=subprocess.PIPE).stdout
    short_dir = p.readlines()[-1] # last line from for command
    if p.close():
        #This means there was an error calling shell command "for"
        #If the incomming full path is short enough and has no spaces,
        # and the incoming name is short enough, then we can just use
        # it, otherwise, we need to throw an error. (max length = 122)
        if (len(long_path)<123) and (long_path.find(" ") == -1) and (len(long_name)<=13):
            return (long_path)
        else:
            #1103 = Error converting directory to short name format
            arcpy.AddIDMessage("Error", 001103)
    short_dir = short_dir.rstrip()
    #Add the unshortened file portion back onto the now-shortened path
    short_path = os.path.join(short_dir, long_name)
    return (short_path)
def expandWorkspace(filepath):
    # If the filepath is not absolute, make it so using the arcpy workspace
    if os.path.isabs(filepath):
        return filepath
    elif arcpy.env.workspace != None:
        return os.path.normpath(os.path.join(arcpy.env.workspace, filepath))
    else:
        return os.path.normpath(os.path.join(os.getcwd(), filepath))
def hasWriteAccess():
    #See if the user has write access to the output directory
    # os.access() isn't giving reliable results, so we have to
    # use this alternate approach
    folderToCreate = arcpy.CreateScratchName("", "", "Folder", dirParam)
    try:
        os.mkdir(folderToCreate)
        os.rmdir(folderToCreate)
        return True
    except:
        return False
# Many errors get caught in tool validation, before execution gets this far.
#  However, some error conditions cannot be caught there because
#  validation should not open the .e00 to find out what it contains.
#Try to determine likely causes of errors generated by import71.exe
def checkErrors(errorCode):
    #First check the retval codes
    if errorCode == 1:
        if not hasWriteAccess():
            #No need to check for directory existence.  Framework already did.
            #1250 = User does not have write access to output folder.
            arcpy.AddIDMessage("Error", 1250)
        elif os.path.lexists(outName):
            #12 = <value> already exists
            arcpy.AddIDMessage("Error", 12, outName)
        elif len(outName) > 122:
            #1252 = Full path to output may be too long.
            arcpy.AddIDMessage("Error", 1252)
        elif len(nameParam) > 13:
            #1253 = Output name may be too long.
            arcpy.AddIDMessage("Error", 1253)
        else:
            #856 = An error was encountered while executing <value>.
            arcpy.AddIDMessage("Error", 856, "import71.exe")
    else:
        #So far, I haven't been able to generate any errorCode values
        # other than 1 (tool failed), but just in case...
        #1254 = <value> returned an error code of <value>
        arcpy.AddIDMessage("Error", 1254, "import71.exe", str(errorCode))
def doImport():
    try:
        d = arcpy.GetInstallInfo('desktop')
        import71exe = os.path.join(d['InstallDir'], "bin", "import71.exe")
        # /t indicates to run the .exe in DOS mode.
        retcode = subprocess.call(
                [import71exe, inName, outName, "/t"], shell=True)
    except:
        arcpy.AddIDMessage("Error", 856, "import71")
    if retcode > 0:
        checkErrors(retcode)
#The main block
if not arcpy.GetInstallInfo()['ProductName'] == u'Desktop':
    # Not running from Desktop, generate error
    #1294 = Tool only supported in ArcGIS for Desktop.
    arcpy.AddIDMessage("Error", 1294, "import71")
else:
    # Running from Desktop, process parameters and execute
    inName = getShortName(expandWorkspace(arcpy.GetParameterAsText(0)))
    dirParam = arcpy.GetParameterAsText(1)
    nameParam = arcpy.GetParameterAsText(2)
    outName = getShortName(os.path.join(dirParam, nameParam))
    if os.path.exists(inName):
        doImport()
    else:
        #732 = <value>: Dataset <value> does not exist or is not supported
        arcpy.AddIDMessage("Error", 732, "ImportFromE00", inName)
If anyone can help, it would very much appreciated...
Thank you in advance.
~Jeremy Lake
by Anonymous User
Not applicable
I have used this simple script in the past to batch export .e00 files. First, it converts them to coverages and then to shapefiles. I did not use the import71...I just used the ImportFromE00_conversion" rel="nofollow" target="_blank">http://resources.arcgis.com/en/help/main/10... tool
import arcpy, os
# Workspace for interchange files
arcpy.env.workspace = ws = r'C:\DATA\EffigyMounds\InterChange_Files'
# Output folder
out = r'C:\DATA\EffigyMounds\Fire'
# Creates a folder if it doesn't already exist
if not os.path.exists(out):
    os.makedirs(out)
# List all ArcInfo Interchange files (.e00)
for cov in arcpy.ListFiles('*.e00'):
    arcpy.ImportFromE00_conversion(cov, ws, cov.split('.')[0])
    print 'Converted %s' %cov
# Exclude Interchange files and info folder
for cov in arcpy.ListFiles():
    if not '.e00' in cov and cov != 'info':
        arcpy.env.workspace = os.path.join(ws,cov)
        for fc in arcpy.ListFeatureClasses('*polygon'):
            shp = os.path.join(out, '%s.shp' %cov)
            arcpy.FeatureClassToFeatureClass_conversion(fc, out, shp)
            print 'Converted Coverage to %s' %shp
I just set a workspace that had a bunch of .e00 files and looped through them to convert to coverage. It then loops through each coverage folder and extracts the polygon files and saves them as a shapefile named after the .e00 file name. The parts you would need to change are highlighted in red.
