Model Builder Calculate Field Hangs
4341
12-30-2010 06:01 AM
PhilipRichardson
I have a built a model to add several fields to a table, then calculate the values from existing fields.  This would appear to be a simple task, but model builder hangs after a few iterations.  The problem seems to be with empty records.  It reports an error for each empty record it encounters, then it just seems to lock up.  I can accomplish the task in ArcMap by just telling Field Calculator to ignore the errors, but I was hoping to automate the task.  I have also tried Pyton script, but it hangs just like Model Builder.  Any thoughts?
ChrisSnyder
Honored Contributor
As memory serves, this was a big issue with v9.2 (Field Calculator hangs)... I recall having this issue especially for large tables > 500k records.
The one guaranteed fix is to use an update cursor via a Python script in lieu of the CalculateField tool.
LornaMurison
If the problem is only with empty records, could you just add a clause in your calculate field expression that deals with empty records.  i.e. if Field1  = "" then Field2 = "" (or if Field1 isnull ...)?
PhilipRichardson
You are correct.  The problem exists with nulls and empty records.  I just figured this out today, by selecting only records with values before the field calculation.  It adds some steps in the model, but it now works.
PhilipRichardson
Unfortunately, the model is not working like I originally had hoped.  The difficulty is with zero length string records.  I have been trying to get a VB expression that would identify zero-length records. If a zero-length record exists, then populate the new field with a null, else calculate the new record.  The model converts a date expressed as a string to an actual date record.
PhilipRichardson
This is what I decided to do.  Instead of populating the new field with nulls, I used a date 1/1/1900, which I can use as a flag later.  To handle the zero-length string problem, I needed a VB script to recognize a zero-length cell, and substitute a date 1/1/1900.
dim pstart1 as string
dim pstart2 as string
pstart1 = [Date_Start]
if pstart1 = "" then
pstart2 = "1900-01-01"
else
pstart2 = pstart1
end if
[Date_Start] is the original field with dates expressed as a string.  The field calculator converts [Date_Start] to [New_Date], which is date format.  [New_Date] = pstart2
