Missing Data after a Merge of shapefiles
1156
06-29-2010 11:03 AM
ZachRussell
I'm new to ArcGIS so I'm hoping I'm just missing something.  Heres my problem.  I have 9 shapefiles that I'm merging into one, but when I do this I'm missing data.  Its very random too.  Any idea to try would be very appreciated.  Thanks.
-zach
AllisonShaw
Hi Zach,
Did you ever get an answer about what was causing missing data when you merged shapefiles?  I just had the same problem.  Please let me know if you've figured it out.
Allison Shaw
JeffWade
I'm having a similar problem.  I have several road sections that I want to combine into a single feature.  When I use the merge command under the edit menu, the shape_length field turns to 0 and both lines disappear from the map.  A single feature shows up in the attribute table, but since its length is 0, there's nothing to display.  Any ideas as to what I'm doing wrong?
