Minimum length & width of irregular polygons
2788
11
02-13-2013 11:15 AM
LisaAngstadt
I have had a request to find polygons within our parcel layer a with minimum width of 1000' and length of 1000'. I tried converting polygons to lines, but not all lines are split appropriately, so it did not yield correct results. The majority of our parcels are irregular polygons, so I cannot use the Bounding Box tool. Any suggestions?
Lisa Angstadt
JamieSorensen
I believe I had to do something similar recently.  Try this:
http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=3D230972-1422-2418-34A5-2F3FF...
If you use the 'minimum bounding rectangles' option, you will be able to get a length and width for every individual polygon.
JoelCalhoun
I had trouble getting to the previous poster's link so I though I would recommend using Esri's Minimum Bounding Geometry tool.
First I would explode your parcels into single part features and then instead of using a fishnet you could create bounding envelopes around the exploded parcel polygons.
The shape of the envelope depends on the method selected.  Most of the options output a polygon envelope containing the input feature class attributes and if you check the box "Add geometry characteristics as attributes to output (optional)" the length and width.  You could then do a selection for any that have both an MBG_Width and and an MBG_Length >= 1000'.
Best of luck,
Joel
