Merging Strings for a new key
823
01-07-2022 04:36 PM
DEWright_CA
So I am updating a working in 10.8.1; before we migrate to Pro. I have a couple existing values (quarter and year_2dig) that we use. I an wanting to do something like this:
valuePrefix = "Q" + str(quarter) + str(year_2dig) + "_"
Then
arcpy.CalculateField_management(loccode_fc, "QRTR_KEY", '"valuePrefix !OBJECTID!"', "PYTHON","")
So I would have a new unique value that says Q122_1 ... etc for each row
But instead I get "colPrefix + 1" as the value...  Ideas?
Tags (3)
JohannesLindner
MVP Frequent Contributor
valuePrefix = "Q" + str(1) + str(22) + "_"
'"' + valuePrefix + "!OBJECTID!" + '"'
# '"Q122_!OBJECTID!"'
That doesn't seem right.
'"' + valuePrefix + '"' + " + str(!OBJECTID!)"
# '"Q122_" + str(!OBJECTID!)'
Have a great day!
Johannes
DuncanHornby
MVP Notable Contributor
It looks like you are erroneously embedding your string within the string and using the wrong python parser,
Your code should be:
arcpy.CalculateField_management(loccode_fc, "QRTR_KEY", '"' + valuePrefix + "!OBJECTID!" + '"',"PYTHON_9.3","")
JohannesLindner
Have a great day!
Johannes
DEWright_CA
Perfect; so I was close; I thought it was just a mixture of the right set of quotes and double-quotes just was running out of places to try.
JohannesLindner
# CalculateField can be a little hard to understand, because you have to pass
# a string that evaluates to a correct Python expression. Biggest pitfall that
# I see on this forum is concatenating strings, because people get mixed up
# with the quotation marks of their expression and the quotation marks _around_
# the expression (that make it into a string).
# It's not clear from your question where quarter and year_2dig come from,
# chose the correct expression from below. Alo, note the double quotes inside
# the expression and the single quotes to turn the expression into a string.
# if quarter and year_2dig are fields in the table, this will result in
# '"Q{}{}_{}".format(!QUARTER!, !YEAR_2DIG!, !OBJECTID!)'
expression = '"Q{}{}_{}".format(!QUARTER!, !YEAR_2DIG!, !OBJECTID!)'
# if quarter and year_2dig are python variables, this will result in
# '"Q122_{}".format(!OBJECTID!)'
expression = '"Q{}{}_'.format(quarter, year_2dig) + '{}".format(!OBJECTID!)'
arcpy.CalculateField_management(loccode_fc, "QRTR_KEY", expression, "PYTHON_9.3", "")
Have a great day!
Johannes
