merge vector data
986
01-13-2012 05:56 AM
IoannisChatzimanolis
I am currently editing a vector dataset, which I cut in smaller segments to be able to use it in arcPad...
after editing the separated datasets, I want to bring them back together, in order to use them as a single vector dataset.
what is the best way to do this?
in case of merging them again, is there a possibility of losing data, or the assemblage to go wrong?
thanx
ChrisSnyder
Honored Contributor
Either the Merge or Append tools are what you are looking for (accessed via ArcToolbox).
There is always a chance of things not going the way we think the will. Make a backup copy.
Append was the tool I used with success. My issue was that I had to manually delete some vectors in order to avoid duplicates, but fortunately it involved a small rural region with no complexity...
thanx again
Remember to always backup!:)
