Measuring distance from a point inside a polygon to the frontier
1243
03-08-2021 01:16 PM
JPANOMX
Dear community,
I am trying to measure the distance from points inside a polygon to polygon’s frontier.  tried the Near Distance command but it only measures the distance for points outside the polygon. For the features that are inside, it returns 0. What command should I use?
jcarlson
MVP Alum
I would convert the polygon to polyline first, then run the Near Distance tool.
- Josh Carlson
Kendall County GIS
jcarlson
MVP Alum
- Josh Carlson
Kendall County GIS
DanPatterson
Feature Vertices To Points (Data Management)—ArcGIS Pro | Documentation
Generate Near Table (Analysis)—ArcGIS Pro | Documentation
if you are doing analysis beyond a simple shortest distance to the perimeter analysis
... sort of retired...
