Match three rasters in a if/else loop?
1679
02-01-2021 06:16 AM
KathleenHoenke
I had created a script with help from the community that takes two rasters of the same name and merges them together (here). I now need to bring in a third raster and mosaic them together as well. However, when I go about matching them, I get this error
File "<string>", line 45, in <module>
IndexError: list index out of range
 I wanted to see if I'm going about this the wrong way or if this is even possible to match in this way? TIA!
import arcpy
import os
from arcpy import env
#not a fan of stating the obvious, but change the paths below to your fgdbs
#also keep the r then surround the path in quotes
#fgdb of rasters being merged
pluv_fgdb = r'E:\FATHOM\2020FATHOM\Analysis\Pluvial_1in100\Pluvial_1in100_Processed.gdb'
fluv_fgdb = r'E:\FATHOM\2020FATHOM\Analysis\Fluvial_1in100\Fluvial_1in100_Processed.gdb'
nhd_fgdb = r'E:\FATHOM\2020FATHOM\Analysis\NHDplusMedium_flowlines_Rast_Expand_HUC02.gdb'
#preferably empy fgdb to put outputs
output_fgdb = r'E:\FATHOM\2020FATHOM\Analysis\Final_Floodplain_Bounds_No_NHD.gdb'
#list all the rasters
arcpy.env.workspace = pluv_fgdb
pluv_rasters = arcpy.ListRasters("*", "GRID")
print (pluv_rasters)
arcpy.env.workspace = fluv_fgdb
fluv_rasters = arcpy.ListRasters()
print (fluv_rasters)
arcpy.env.workspace = nhd_fgdb
nhd_rasters = arcpy.ListRasters()
print (nhd_rasters)
#make a dictionary of source raster path
#to clipping fc and source name
#NB relies on names after the '_' being equal
input_floodplain_pieces_dict = {}
for pluv_raster in pluv_rasters:
    for fluv_raster in fluv_rasters:
        for nhd_raster in nhd_rasters:
            if pluv_raster.split("_Mask")[1] == fluv_raster.split("_Mask")[1] == nhd_raster.split("_")[-1]:
                pluv_raster_path = os.path.join(pluv_fgdb, pluv_raster)
                fluv_raster_path = os.path.join(fluv_fgdb, fluv_raster)
                nhd_raster_path = os.path.join(nhd_gdb, nhd_raster)
                out_raster_name = nhd_raster + "_Floodplain"
                out_raster_path = os.path.join(output_fgdb, out_raster_name)
                OutMedResFloodplain = arcpy.management.MosaicToNewRaster(pluv_raster_path, fluv_raster_path, nhd_raster_path, output_fgdb, out_raster_name, "NAD_1983_Albers", "8_BIT_UNSIGNED", "30", "1", "Last", "First")
DavidPike
MVP Notable Contributor
I've not gone though the whole code, only the error you have, but:
The mosaic to new raster tool Mosaic To New Raster (Data Management)—ArcGIS Pro | Documentation expects the input rasters argument to be a list.  The tool is misinterpreting each raster as an incorrect argument to the tool.
try:
OutMedResFloodplain = arcpy.management.MosaicToNewRaster([pluv_raster_path, fluv_raster_path, nhd_raster_path], output_fgdb, out_raster_name, "NAD_1983_Albers", "8_BIT_UNSIGNED", "30", "1", "Last", "First")
DavidPike
I'd get rid of any references to the dictionary, it just confuses things.
It's likely when you call the index [1] on the .split list.  You should really add print statements to see what's going on - such as:
print(pluv_raster.split("_Mask")[1])
KathleenHoenke
Thank you - that did work and help me to make sure I got the 0 and 1s correct.
Now I'm receiving this error:
arcgisscripting.ExecuteError: ERROR 000622: Failed to execute (Mosaic To New Raster). Parameters are not valid.
ERROR 000628: Cannot set input into parameter coordinate_system_for_the_raster.
DavidPike
try:
KathleenHoenke
Perfect, thank you!
