Make Query Table problem
8720
14
10-22-2015 09:11 AM
AndreasStelter
I am trying to join three tables from the same FGDB via Make Query table.
Validation in Model Builder shows no errors. If I run my tool from Model Builder the following error messages are displayed:
ERROR 999999: Error executing function.
An expected Field was not found or could not be retrieved properly. [S_LX_Abzugsbefreiungen_Query]
An expected Field was not found or could not be retrieved properly. [OID]
Failed to execute (Make Query Table).
What's wrong? S_LX_Abzugsbefreiungen_Query is the name of the table that should be created.
The error persists even if I remove the SQL query, so the reason cannot be a syntax error in th query.
BTW: I'm using ArcGIS 10.0 SP5.
Thanks for any help
Andreas
DanPatterson_Retired
for the benefit of others...what was it?
AndreasStelter
I left the model unchanged (so I didn't have to use Make Query Table) and retrieved the information I needed in C# code instead.
CharalambosMattheou4
I have the same problem here. Data are stored in the same workspase. Any advice? Is there a step by step tutorial with relevant dataset available?
Thanks
Charalambos
Solved . " " in sql statement was the problem.
regards
Charalambos
RichardTruong
Yulp, remove the " " in the sql statement will resolve the issue.   Thank you.
