Make Image Server Layer: output goes where? MakeImageServerLayer_management
1067
12-01-2010 05:35 PM
JerryGarcia
The following script runs successfully, but no output is added to arcmap or arcgis explorer desktop.
Any suggestions?
Can I save the output to a layer file via code or script?
####Usage: MakeImageServerLayer_management in_image_service out_imageserver_layer
##                                       {template} {ID;ID...} {mosaic_method}
##                                       {order_field} {order_base_value} {lock_rasterid}
try:
    import arcpy
    arcpy.env.workspace = r"C:/workspace"
    input1 = "http://splitboard/ArcGIS/services/imageryData_Mosaic/ImageServer"
    arcpy.MakeImageServerLayer_management(input1, "mdlayer", "431778.367783651 4583563.68601919 432331.485840777 4583563.68601919", "1;2;3;4",\
                                          "LockRaster", "#", "#", "1")
    print arcpy.GetMessages()
except:
    print "Make Image Server Layer example failed."
