load data from multiple shapefiles into single geodatabase feature class using script
1365
04-26-2010 07:59 AM
MikeSteven
I have data on a theme in 3 different shapefiles - a point shapefile, a line shapefile and a polygon shapefile and I want to put all of the data into 1 shapefile and I want to automate this in a script. I buffered the point and line shapefiles so I now have 3 polygon shapefiles and I can manually load those shapefiles into a single file geodatabase feature class with the load data tool but I can't see how I could automate this in a script. Does anyone have any ideas? Might it be possible using ArcObjects?
Mike.
MikeSteven
Oops, just realised I can use the append tool
