Layer to KML issues.
3034
10
12-14-2011 01:34 PM
StephenRamirez1
I have point data with fairly simple attributes showing address, water usage, etc. I can convert this to kmz fine. I run into problems when I want to create a field that turns into a link once viewed in google maps/earth. I use the field calculator to insert the address into "http://www.maps.google.com/maps?q="address" austin,tx" I use %20 instead of spaces to not break the hyperlink string.
The field looks good in ArcMap and turns out exactly how I want it but when I go to convert using "layer to kml" I receive a windows error during the processing that basically says "Arc SOCP exe" has failed. I have tried exporting the table and re creating the files, still does not work. I know the problem only arises when I have that long hyperlink string field included.
I tried disabling background processing, the file went through, but google earth could not open it, it came up with "parse error..etc"
I tried using google earth pro to process the .shp into kmz instead, but I was having a lot of trouble with the bubbles/tables. I would much prefer to just be able to export it from ArcMap, ready to go into google earth.
I really appreciate any help.
KevinHibma
ArcMap Service pack.
You can find the link to download it here:
http://resources.arcgis.com/content/patches-and-service-packs?fa=viewPatch&PID=160&MetaID=1807
ArcGIS Desktop (ArcInfo, ArcEditor, ArcView, ArcGIS Eval Edition)
ArcGISDesktop10sp3.msp  401 MB
