Join disappears
3980
01-22-2015 01:59 PM
JohnBrand
Hello,
I have a join set up between a feature class and an Excel table and everything works great.
When I open a second mxd that has the same join set up between the same feature class and Excel table, the join disappears.  When I try to recreate the join, I get this message
Failed to connect to database
General Function failure
External table is not in the expected format.
Is there a work around for this?  The table has to stay in Excel format so that other non-GIS users can make updates to it.
Tags (1)
AngieBraun
I had the same problem when I added the Excel table to my .mxd from a file folder. I imported the table into a geodatabase and the problem went away.
KyleDixon
Try using a DBF table or load into a GDB.
JamesPierce
Excel is a good way to quickly view XY data, but not a good way to permanently operate.  Like the others said.  GDB is the best.  Only a couple more mouse-clicks to get it done.
