itself crossing polygons
2090
10-25-2012 05:25 AM
AndreasDaim
hey,
ist it possible to check (or select) all itselfcorssing polygons? Crossing results from hand held GPS polygon capturing:
[ATTACH=CONFIG]18710[/ATTACH]
gz
andreas
DanPatterson_Retired
did you run the Check Geometry or Repair Geometry tools?
AndreasDaim
worked out fine - thx!
regards
andreas
AndreasDaim
hm, just figured out, that just a few polygons were selected by the check geometry tool.
there are many left, with crossing lines. some other action?
gz andreas
Make sure that you don't have any features selected in the table or in the dataframe when you run the repair geometry.  Also, the apparent self intersections may represent multiparts of a polygon and are indeed valid geometry
AndreasDaim
oh - thx a lot, think I had selected something, therefore no new results appeared!
gz andreas
