Issues with Integrate and SplitLineAtPoint Tools(Seeking for help)
1887
10-12-2024 09:29 PM
CyrusTsang
Hello Esri Community,
I am currently working on processing GTFS (General Transit Feed Specification) stop_times.txt data using ArcPy in ArcGIS Pro to create bus routes and stops, as well as to add durations based on each bus route. However, I'm encountering issues where the split lines are not being correctly split at the stop points. Specifically, some bus routes are not being split as intended, resulting in inaccurate segmentation of the routes. Can anyone give me a hand with this, thank you a lot.
Workflow Summary:
1.Data:
  • BusRoutes(FB_ROUTE_LINE_259X)(route line): Created with fields such as trip_id, duration, ROUTE_SEQ, COMPANY_CODE, etc
  • BusStops(BusStops)(point): Created with fields like stop_id, arrival_time, departure_time, etc.
    Spatial Reference:
Both BusRoutes and BusStops are set to Web Mercator Auxiliary Sphere (EPSG:3857) to ensure consistency.
2.Geoprocessing Steps:
  • Integrate Tool: Applied to align bus stops with bus routes using a specified cluster_tolerance.
  • SplitLineAtPoint Tool: Intended to split bus routes at each bus stop to create segments between consecutive stops.
    The Problem:
Despite following the workflow, I observe that:
Incorrect Splits: Some bus routes are not being split correctly at the stop points.
Manual Processing: Performing the same operations manually in ArcGIS Pro's SplitLineAtPoint tool results in the same issues.
Below is part of the code:
# Define in_features as a list
integrate_inputs = [fc_routes_path, fc_stops_path]
# Define cluster_tolerance based on your environment settings
cluster_tolerance = "0.01 Feet" # Adjust as needed
# Check spatial references
routes_sr = arcpy.Describe(fc_routes_path).spatialReference
stops_sr = arcpy.Describe(fc_stops_path).spatialReference
if routes_sr.factoryCode != stops_sr.factoryCode:
logging.error("Spatial references do not match between BusRoutes and BusStops.")
exit()
else:
logging.info("Spatial references match between BusRoutes and BusStops.")
logging.info("Finished creating bus routes and stops feature classes.")
split_lines_output = os.path.join(gdb_path, 'BusRoutes_Split')
if arcpy.Exists(split_lines_output):
logging.info(f"{split_lines_output} already exists. Deleting...")
arcpy.management.Delete(split_lines_output)
try:
# Use keyword arguments for clarity
arcpy.management.Integrate(in_features=integrate_inputs, cluster_tolerance=cluster_tolerance)
logging.info("Integrate tool executed successfully.")
except arcpy.ExecuteError:
logging.error("ArcPy ExecuteError during Integrate:")
logging.error(arcpy.GetMessages(2)) # 2 captures only error messages
exit()
except Exception as e:
logging.error(f"Failed to run Integrate tool: {e}")
exit()
# Perform the Split Line at Point operation
arcpy.management.SplitLineAtPoint(fc_routes_path, fc_stops_path, split_lines_output, "1 Meters")
logging.info(f"SplitLineAtPoint executed successfully and output saved at {split_lines_output}")
DanPatterson
MVP Esteemed Contributor
both the Integrate and
Pairwise Integrate (Analysis)—ArcGIS Pro | Documentation
recommend not specifying a cluster tolerance to ensure that the one specified for the spatial reference of the input data is used.
In any event a 0.01 foot distance is pretty small and you have to decide whether your bus stops have been located accurate enough to ensure that they comply to this distance.
If you must use a cluster tolerance value, try 1.0 feet to try to capture point locations that are farther away from the line than you expect.
... sort of retired...
CyrusTsang
Thank you for your guidance on adjusting the cluster tolerance settings and your help. However, after removing the cluster tolerance as recommended, I'm still encountering the problem that the bus routes are not being split correctly at the stop points.
DanPatterson
It would be useful if you showed the location of the bus stops to the route after Integrate, perhaps the tolerance isn't any good and web mercator coordinate system wouldn't help matters for things involving distance.  So in short, what is the actual distance relaytive to the lines and have you considered using data in a differenc coordinate system?
