Is there a way to batch the tool Create feature class from XY table?
1861
08-13-2011 10:24 PM
PatriciaMurrieta
Hi, I have many ascii files with xyz data from surveys and I want to transform them to points. I have tried already other tools like ASCII 3D to feature class but or some reason it seems not to work. The only tool that works fine is the arccatalogue "create feature class from XY", but as they are many files I want to batch the process. Do you know if this is this possible?
Many thanks!!
DaleHoneycutt
Make XY Event Layer tool.
To "batch" the process, right-click the tool and select Batch.
Or write a model.
