Is it possible to count points in polygon and print out what each polygon contains
4229
7
06-18-2021 03:26 AM
Cookie010103
Viewed 9 times
Sorry for the weird title but here's my sample table for further description:
I have a original point layer:
IDNameX(latitude)Y(longtitude)
ID1DogA1
ID2CatA1
ID3BirdB1
ID4CatA2
ID5CatB1
ID6DogA1
Those points are inside a grid layer, lets say 2x2 for instance, and the points are inside the grid. I'll try my best to demonstrate it in the follow table:
B
1. . . (Three points, which are ID1, ID2, ID6). . (ID3, ID5)
2. (ID4)(NULL)
Next, I use the count_points_in_polygon functino and create a new layer, which by default adds a column NUM_POINT.
Grid_ID NUM_POINT
A13
A22
B11
B20
But what I actually want is a table that shows which 'Name's are in each polygon, like the following table shows.
Grid_IDNUM_POINT Name
A13Dog, Cat
A21Dog
B12Bird, Cat
B20-
Any solution or keywords is much appriciated, thank you!
JohannesLindner
import arcpy, os
points = "Point_layer_or_feature_class"
polygons = "Polygon_layer_or_feature_class"
out_table = "PathToOutputTable"
# Intersect points and polygons
in_features = [points, polygons]
intersect_points = "memory/intersect_points"  # this is for ArcGIS Pro
# intersect_points = "in_memory/intersect_points"  # this is for ArcMap
arcpy.analysis.Intersect(in_features, intersect_points)
# you now have a point feature class with the attributes of the original points and the attributes of the polygon the points are in.
# read the data into a list
fields = ["Grid_ID", "Name"]
point_data = [row for row in arcpy.da.SearchCursor(intersect_points , fields)]
# get the grid ids from the polygons
grid_ids = [row[0] for row in arcpy.da.SearchCursor(polygons, ["Grid_ID"])]
# if you don't care about polygons with 0 points in them, use this instead:
# grid_ids = list(set([p[0] for p in point_data]))
# create out_table
try:
    arcpy.management.Delete(out_table)
except:
    pass
arcpy.management.CreateTable(os.path.dirname(out_table), os.path.basename(out_table))
arcpy.management.AddField(out_table, "Grid_ID", "LONG")
arcpy.management.AddField(out_table, "Count", "LONG")
arcpy.management.AddField(out_table, "Name", "Text")
# for each grid_id, search point_data for all points with that grid_id, get the count and all names, write the result into out_table
with arcpy.da.InsertCursor(out_table, ["Grid_ID", "Count", "Name"]) as cursor:
    for grid_id in grid_ids:
        names_in_polygon = [p[1] for p in point_data if p[0] == grid_id]
        count = len(names_in_polygon)
        unique_names = ", ".join(set(names_in_polygon))
        cursor.insertRow([grid_id, count, unique_names])
Have a great day!
Johannes
Cookie010103
I will try this soon, should this work in normal ArcGIS or Qgis? Anyways Thank you so much!
JohannesLindner
This is for ArcGIS! Comment out line 9 or 10, depending on whether you work with ArcGIS Pro or ArcMap.
I'm very sure you could do something like that in QGIS, but I dont know how, as I don't work with QGIS.
Have a great day!
Johannes
Cookie010103
I must say I'm an absolute beginner to python in GIS, mostly using the default functions for analysis. During the process several problems occurred.
1. Assuming the 'PathToOutputTalbe' is a variable where the table should be generated, So I created an empty file for it, but I'm not so sure about it.
2. It returns this error message, and generates almost a blank table as a result.
Runtime error
  File "<string>", line 30, in <module>
SystemError: error return without exception set
3. Also, I might not be descriptive enough that the grid layer is actually a polygon, which should have its spacial value showed in the final result so I can visualize it on the map. In my case it's the 'left', 'right', 'top', 'bottom' column I assume.
I came up with the idea that can I simply generate 4 fields, but it didnt work as expected.
arcpy.management.AddField(out_table, "Left", "FLOAT")
arcpy.management.AddField(out_table, "Right", "FLOAT")
arcpy.management.AddField(out_table, "Top", "FLOAT")
arcpy.management.AddField(out_table, "Bottom", "FLOAT")
  At this point I might just post my original working table for your better understanding.  The desired result is that I can clink on a polygon, and read how many 'Names' are there in the selected polygon. Thank you and sorry for the dumb questions.
Cookie010103
import arcpy, os
points = "merge_simplified_new"
polygons = "Intersect_5x5_reprojected"
out_table = "C:\Users\lcdc7\Desktop\ArcGIS\Output"
try:
except:
    pass
p.s. This is the final code I use.
DuncanHornby
MVP Notable Contributor
Absolutely NO CODE is required to answer this question just a little knowledge on the correct usage of the SPATIAL JOIN tool.
The trick is to set the Merge rule to JOIN on your Name field in the field mapping as shown below. Also adjust field length as required.
The output is a new FeatureClass grid with join count and concatenation of values from your Name field, see example below.
Any code is overkill and I suspect slower if your datasets get very large.
JohannesLindner
@Cookie010103: Sorry, kinda forgot about this thread. You should absolutely use Duncan's solution.
@DuncanHornby: This is great, thanks! Sometimes I jump to using code without checking out tools I don't know... TIL
Have a great day!
Johannes
