Inserting Current Date into Filename via Modelbuilder
30141
17
02-04-2011 05:46 AM
JeffPickles
Is there a way to programmatically export a shapefile or feature class from Modelbuilder that has the current date in its filename?
ShariForbes
Helped me too! Never too late.
MichelleWalker
thanks so much - this worked great and really helped me
curtvprice
DanSadler1
Almost a decade after you posted, and your answer still works - even in ArcGIS Pro! The (possible?) difference from ArcMap is you access Calculate Value in Pro via its own item in the ModelBuilder ribbon under Utilities and set the data type as string.
I hope this helps other ArcGIS Pro folks who surf here as this thread was the top search engine result.
WilliamJackson4
Odd, the example doesn't seem to work for me. I'm running 10.3.1. If I run in a python script it works fine but not so much in Model Builder where the variable is assigned a "1". Any suggestions?
by Anonymous User
Not applicable
William, I was having the same issue but then I connected the output date (green bubble) as a precondition variable to the tools (yellow bubble) that I ran and it worked for me!
LindsayRaabe_FPCWA
MVP Regular Contributor
I seem to be having similar issues. I was getting the "1" output but now I get the date but also keep getting errors about incorrect naming. Can anyone tell me what name is wrong? The original demo tool provided further up has the same issue!
Lindsay Raabe
GIS Officer
Forest Products Commission WA
curtvprice
