Inline Variable Substitution for Dynamic Database Connection String
1955
01-06-2023 10:57 AM
ABishop
MVP Alum
Hopefully I am posting this in the right place and this makes sense to somebody who can assist me...
I wrote a series of python scripts which extracts data tables from views in our CAMA database.  Our CAMA database rolls over each year with a new year and consequentially the year has to be updated in the database connection string and view name.  This wouldn't be so bad if there weren't 30+ lines in each script and approx. 10 scripts that have year-dependent values.
I have looked into inline subs using variables and attempted a couple of different methods.  I have pasted one test script of a view extraction example below.  Could somebody review it and assist me with where I am going wrong?   (Note: I am using ArcGIS Pro 3.0.3, ArcGIS Server 10.8, and Enterprise geodatabase in MS SQL Server version 14.0.1000.169)
# Process: import arcpy modules
import arcpy, os, sys
from arcpy import env
from datetime import datetime
import ctypes
ctypes.windll.kernel32.SetConsoleTitleW('02_ExtractViews')
env.workspace = r"K:\GIS_UPDATE\DATA\EXTRACTVIEWS"
env.overwriteOutput = True
# Process: start timer
startTime = time.perf_counter()
# Process: set local variables
fieldmap = ""
RollYear = "2023"
AddressExtractView = r"K:\GIS_TOOLS\DB\CAMA(%RollYear%).sde\(%RollYear%).dbo.AddressExtractView(%RollYear%)"
gdb = r"K:\GIS_UPDATE\DATA\EXTRACTVIEWS\EXTRACTVIEWS.gdb"
# Process: copying AddressExtract View to Address1 table in EXTRACTVIEWS.gdb
arcpy.conversion.TableToTable(AddressExtractView, gdb, "Address1", '', fieldmap, '')
# Process: end timer
endTime = time.perf_counter()
elapsedTime = round((endTime - startTime) / 60, 2)
print("Script finished in {0} minutes".format(elapsedTime))
# Process: date and time stamp
date = datetime.now().strftime("%Y_%m_%d-%I:%M:%S_%p")
print("Date and time stamp: "+f"{date}")
# Process: provide input to stop script - uncomment input below if you need to see the script final output in the command window
input('Press ENTER to exit')
Thank you in advance,
Amanda
Amanda Bishop, GISP
RhettZufelt
MVP Notable Contributor
For variable substitution in the AddressExtractView string?  You can use f string substitution like such:
AddressExtractView = fr"K:\GIS_TOOLS\DB\CAMA{RollYear}.sde\{RollYear}.dbo.AddressExtractView{RollYear}"
If I understand the question correctly.
R_
RhettZufelt
R_
ABishop
MVP Alum
Thank you R_!
I'll try it and get back with you.
Amanda Bishop, GISP
ABishop
MVP Alum
Thank you @RhettZufelt !  This worked beautifully. 😁
Amanda Bishop, GISP
