inline variable and input event table
1913
06-28-2011 10:36 AM
EvanBossett
I have a geoprocessing task which users a predefined Input Route Feature and Input Event Table to linearly reference some point and display them in my Silverlight application.  It works fine.
I want to make the "Input event table" a variable so I can send different input tables from silverlight to linearly reference.  However, I haven't been able to get this to work.
I keep getting the error:"Geoprocessing service failed: The remote server returned an error: NotFound."
I input this as a local path to my connection (it works if no variable is used)
C:\sdeConnect\TEST_DB.odc\dbo.TEST_VIEW
however, if i use a variable for it, it fails.  I tried leaving the entire variable blank and inputting the entire string.
i also tried C:\sdeConnect\TEST_DB.odc\%TEST_INPUT%  and input only the table name.
but i got the same error.
any help would be greatly appreciated.  thank you.
EvanBossett
n/m I was able to figure out the issue by using another input String parameter
