Incorrect syntax near the keyword 'FROM'
5556
7
10-01-2015 02:06 PM
ChrisPolley
i'm having an issues here, I'm trying to Select by attributes and using the following
(EXTRACT(YEAR FROM CURRENT_DATE) - EXTRACT(YEAR FROM "DateReported") < 10) AND "Facility" = 'Main' AND  ("Cause" = 'Other' OR "DateRepaired" IS NULL)
and I'm getting the following error
Incorrect syntax near the keywrod 'FROM'
JenniferMcCall4
Have you tried breaking up the statement into smaller individual statements to see which section has the error?
ChrisPolley
Yes and no
JoshuaBixby
MVP Esteemed Contributor
It seems EXTRACT is working and CURRENT_DATE, is the issue with the DateReported field?  Does this work?
  • (EXTRACT(YEAR FROM "DateReported"))
DarrenWiens2
Can you get it to work for a simpler expression (e.g. "EXTRACT(YEAR FROM "DateReported")=2010")?
JoshuaBixby
What about moving the right-parenthesis over to before the less than comparison:
(EXTRACT(YEAR FROM CURRENT_DATE) - EXTRACT(YEAR FROM "DateReported")) < 10 AND "Facility" = 'Main' AND ("Cause" = 'Other' OR "DateRepaired" IS NULL)
ChrisPolley
Tried that and I'm getting the same error.
DanPatterson_Retired
do the following and tell if it works
  • (EXTRACT(YEAR FROM CURRENT_DATE))      - note the brackets!
  • ((EXTRACT(YEAR FROM CURRENT_DATE) - EXTRACT(YEAR FROM "DateReported"))  < 10 )    - ditto!!
If either fails, let us know which one... build the steps incrementally and manually watching that you may need to add brackets as I have done in the above 2 examples
