in_file_filter option of Generate Attachment Match Table geoprocessing tool
459
02-24-2023 09:10 AM
BarryG
I have a feature class, generated from a table, which contains fields including an endpoint id and another with the meter id.  The problem is that the pdf documents to attach contain more text in the title than either one of the id's.  So, what I would like to do is use the Key Field name in the Input Data Filter option, but don't think that is an option. Based on the geoprocessing tool Help page, it appears that only wildcard text or file type may be entered for the Input Data Filter, correct?
Sample attachment title: 100045493_RIGNEY__CHARLES_47192742.pdf
https://pro.arcgis.com/en/pro-app/3.0/tool-reference/data-management/generate-attachment-match-table...
