I've imported 5 different spreadsheets, and on 2 of them the last column has disappeared.
I tried changing the size of the font didn't help. I tried setting a print area.
Please someone help me with this frustrating issue.
Thanks!
One of the cause of the missing header that I experienced was that the header name has space/s and I just added underscore on it and it work. Have you set the target correctly during loading of schema?
What is the exact header name on your spreadsheet that is missing? Is there an special character on it?
The Header name is AREA. Its a list with a bunch of columns and it has Job Title, Name, Area as the headers.
as i menioned 5 spreadsheets all the same, but 2 show up with the last column missing.
Well, I'm not sure what the problem is/was, but after carefully adjusting the columns to not have any extra space and even adjusted some font size and it fit. BUt if i move it even a millimeter, the column disappears!
It is still frustrating however, becuase now some words in some of the columns are slightly smaller. I'm just glad the column re-appeared!
Thanks for responding.
