Import Error libarcgisscripting_pluginstub.so
1227
05-03-2010 02:35 PM
PrashanthSukumaran
I am trying to execute a python geoprocessing script in my unix environment. We have ArcGIS server 9.3 installed on Sun Solaris 9. Python was installed along with the server install.
When i execute the script i get the following error.
File "GeocodeShops.py", line 8, in <module>
import arcgisscripting
ImportError: ld.so.1: python: fatal: libarcgisscripting_pluginstub.so: open failed: No such file or directory
My Python script is simple.
# GeocodeShops.py
# Created on: Thu Dec 17 2009 04:23:29 PM
#   (generated by ArcGIS/ModelBuilder)
# Import system modules
# Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
try :
        gp.AddMessage("Started the Geocode Script for Shops.")
        gp.AddMessage("Done geocoding addresses ........")
except:
        print gp.GetMessages(2)
I printed the PYTHONPATH to check if bin was present. "/export/project/gisapp/arcgis93/arcgis/bin" is in the path. I also found that libarcgisscripting_pluginstub.so is in that folder.
What could be causing this error?
Thanks for you help
PrashanthSukumaran
The script works fine in a windows environment with ArcGIS Server 9.3.1.
Any help please!!!
FrankPerks
What version of python are you running the script with?
just type:
python
And it will say the version + if its 64bit or not.
DeeleshMandloi
Before running any python scripts on unix, you must first set the proper environment. This can be accomplished by sourcing the init files provided with ArcGIS Server install on unix.
These init files are present in <arcgis install dir>/servercore/.Server . There are init files for different shells. So if you are using bash shell, you can use
source /arcgis/servercore/.Server/init_server.sh
Now if you run your python script, it should work fine.
Hope this helps
Deelesh
