If statement in Field Calculator
10679
6
05-07-2013 07:25 AM
GregSullivan1
Hello,
I am having problems with if statements in the Field calculator. This is my first time trying to code something in the field calculator. I am familiar with coding as I have used java and visual basic before. I created contours and I have a field that is set to 1 for all contours that are not an interval of 5 and set to 2 for all 5 foot contours. I have created another Field called Layer that I want to populate with a string for Minor and a different string for major contours. Can anyone help with this?
JakeSkinner
Esri Esteemed Contributor
You can achieve this using python.  Here is an example:
[ATTACH=CONFIG]24101[/ATTACH]
JakeSkinner
Hi Greg,
What constitutes the Layer field to have the Minor string, and Major string?  If the other field is 1, should the Layer field have a value of 'Minor'??
GregSullivan1
Yes I am trying to set the Layer field to 'Minor' if the other field = 1 and set the layer field to 'Major' if the other field = 2
JakeSkinner
RichardFairhurst
In VB Script you would do the following:
Parser: VB Script
Use Codeblock: checked
Codeblock:
If [Other_Field] = 1 Then
  Output = "Minor"
ElseIf [Other_Field] = 2 Then
  Output = "Major"
Else
  Output = [Layer] '  Use the existing value of the field being calculated so that it won't change.
End If
expression: Output
JohannaValente
I've been on a 2 hour search for the right code to do my basic If/Then Statement and yours was the only one that worked, thank you!!
RichardFairhurst
Johanna:
I am glad it helped.
