How to project Decimal Degrees coordinates using distance and bearing?
1503
04-12-2017 08:13 AM
MaxWithey
I am working on an ecological research project looking at mammal behaviour in South Africa. I collected the data over 6 months and have over 4000 spatial locations to work with. My method was to take a GPS point of my location (originally in Degree Decimal-Minutes, now converted to Decimal Degrees to make it work in ArcMap), and a distance and bearing to the animal sighted. I now need to project these coordinates using distance and bearing so they reflect where the animal was, not where I was.
I have found online tools that do it, but only singularly. With over 4000 to do this is not an option. In theory it is a simple process, but I have struggled to find a tool that does it.
Any help with this would be much appreciated
I am familiar with ArcGIS,but am no expert and have never worked with python. I am using ArcGIS 10.4 on a basic license.
DanPatterson_Retired
Robert_LeClair
Esri Esteemed Contributor
Do you have some "sample" data I could work with?  The reason I ask is what units were the bearing distance from you to the animal?
