How to intersect two geometry objects with 9.3 geoprocessor
1590
6
06-16-2011 08:13 AM
JörgMohring
Dear colleagues,
I have two geometry objects o1 and o2 created from arrays (e.g. o1 = gp.CreateObject("geometry", "polygon", array1).
Now I would like to intersect them. However
gp.Intersect_analysis("o1;o2",output) does not work, neither does
gp.Intersect_analysis(o1 + ";" + o2,output) work, nor does
gp.Intersect_analysis(str(o1) + ";" + str(o2),output) work.
Can it be that it's simply not possible to intersect geometry objects since the intersect tool requires strings?
Thank you for any help!
Jörg Mohring
ChrisSnyder
Honored Contributor
I could be wrong, but I thought you could only use the geometry objects directly in v10 GP tools (not in v93).
JörgMohring
One can use them in v93 but the use is quite limited it seems. Thank you!
DanPatterson_Retired
check to see how you are creating the object from the example in the 9.3.1 help files
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=966&pid=951&topicname=Using_geometry_objects_...
ChrisSnyder
Honored Contributor
Well, live and learn. I guess that's why I look at these forum posts...
Contrary to my beliefs 5 minutes ago:
1) You can use geomety objects directly in v9.3 (thought that was new in v10)
2) You can pass a list objects (maybe tuples?) directly into the v93 gp tools, and apparently no longer have to use string parameters.
#snipit of ESRI example code
inGeom1 = gp.createobject("geometry", "polygon", ary)
inGeom2 = gp.createobject("geometry", "polygon", ary2)
inGeoms = [inGeom1, inGeom2]
outGeom = gp.createobject("geometry")
newOutGeom = gp.union_analysis(inGeoms, outGeom)
Good to know...
ChrisSnyder
Honored Contributor
Jörg, per your original post, how about:
gp.Intersect_analysis([o1,o2],output)
ChrisSnyder
Honored Contributor
Looks like this statement (at least in v9.3.1) only applies to geometry objects - not on disk FCs, so I wasn't completely wrong...
For example:
inputList = [r"D:\csny490\test.gdb\townships", r"D:\csny490\test.gdb\regions"]
outputFC =  r"D:\csny490\test.gdb\output"
gp.intersect_analysis(inputList, outputFC)
errors out, but
gp.intersect_analysis(";".join(inputList), outputFC)
works fine.
