How to fix Broken Model
13183
12
04-15-2013 05:07 PM
BilalHossain
Hi Fellow
I have developed a model (using model builder, ArcGIS 10) for spatial analysis of my project. The model was quite big and took me 3 days to develop. Every time I add a new tool/process in the model I save it to avoid loosing any work. I was about to finish the model and save it but it did not save, showed a message "failed to save the model", even did not permit to copy the model. Eventually I close it without saving & compromising that I will only lose very last process. But once I close it I saw a red cross mark on my model. I opened it in the edit mode but there is no work at all. I searched into the forum but could not find any solution to repair this. I had a look through the article to repair the broken model (http://resources.arcgis.com/en/help/main/10.1/index.html#//002w00000018000000). It says how to fix the broken tool but does not mention to fix broken model.
Any solution would be appreciated.
Thanks in advance
Bilal
GrahamW
Great tip!
by Anonymous User
Not applicable
I totally agree with the threads.  It happened just now and in the past.  The Modelbuilder is a great tool but it is lacking something important.  There is no way to recover the work using Modelbuilder.  I will adopt your approach in order to save my time and work.
Thanks for sharing your solution!!
GregWhite2
The same thing just happened to me! Argghhhhhhhh
