I have a single NetCDF file that contains daily precipitation data for several years and would like to extract them in a more automatic way.
I am aware I could do it by creating an model builder and within "make netcdf raster layer" make the dimension values variable. However when I add a quite a lot of dimension values, model builder keeps crashing.
That is a print screen of my model:
I am wondering if someone could help me with a phyton scripts for this.
That would be very much appreciated.
netCDF has come up recently, see if there is anything here you can troll
# Import system modules
import arcpy
from arcpy import env
from arcpy.sa import *
# Input data source
arcpy.env.workspace = "C:\prec"
# Set output folder
OutputFolder = "C:\prec\Raster"
# Loop through a list of files in the workspace
NCfiles = arcpy.ListFiles("*.nc")
for filename in NCfiles:
print("Processing: " + filename)
inNCfiles = arcpy.env.workspace + "/" + filename
fileroot = filename[0:(len(filename)-3)]
TempLayerFile = "prec_amount"
outRaster = OutputFolder + "/" + fileroot
# Process: Make NetCDF Raster Layer
# this will convert the FIRST time step in your netCDF file to a raster layer
arcpy.MakeNetCDFRasterLayer_md(inNCfiles, "prec", "lon", "lat", TempLayerFile, "#", "time 01/01/2000 12:00:00 PM", "BY_VALUE")
# Process: Copy Raster
arcpy.CopyRaster_management(TempLayerFile, outRaster + ".tif", "", "", "", "NONE", "NONE", "")
print "***DONE!!!"
print arcpy.GetMessages()
The error message does not have any specific ID so I am not sure why the tool could not succeed:
"Runtime error
File "<string>", line 14, in <module>
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\md.py", line 172, in MakeNetCDFRasterLayer
raise e
RuntimeError: Object: Error in executing tool".
Would anyone have any guess?
inNCfiles should be 'filename' since filename is the name used within the loop ie (arcpy.MakeNetCDFRasterLayer_md(filename..... )
use raw formatting for paths ie ... r"c:\whatever" r"c:\whatever\more"
Try to reformat the code using the code syntax highlighter (click on the ... in your thread but outside of the messages section... click on your thread title to get there)
more later
import arcpy
# Input data source
arcpy.env.workspace = r"C:\prec"
# Set output folder
OutputFolder = r"C:\prec\Raster"
arcpy.MakeNetCDFRasterLayer_md(filename, "prec", "lon", "lat", TempLayerFile, "#", "time 01/01/2000 12:00:00 PM", "BY_VALUE")
print "***DONE!!!"
Thanks Dan. I pasted the code as above.
So, I have replaced inNCfiles either in both entries (i.e. lines 22 and 30) or only at line 30, but I m still getting the same error and I have no clue the reasons why.
"Runtime error
raise e
