How to create a polygon file based on a point grid file
3673
06-14-2016 03:40 PM
BenVan_Kesteren1
Hey,
I know this is going to be classified as GIS101, but I cannot for the life of me find a tool that will do what I require.
I have a point feature class, it has about 1 million points, it represents a flood area, and what I need to create is a polygon which represents the extent of the area affected by this flood. So basically I need it to 'shrink wrap' my points. See below my technical sample drawing, I am trying to create the extent (red) polygon, around the existing points (black dots).
What tool do I need???
DanPatterson_Retired
You want a concave hull, there used to be several, but Richard Fairhurst​ 's toolset might just do the work for you
Bruce Harold's Concave Hull Estimator Tool Enhanced
BenVan_Kesteren1
Thanks Dan, I am running the tool now to see if it does what I am looking for!
Cheers!
JayantaPoddar
You could try Aggregate Points—Help | ArcGIS for Desktop
Define a higher value for the aggregation distance, so that it forms a single polygon.
Think Location
