How to convert GPS collar data to sequential path
837
01-10-2013 01:46 PM
MorganGraham
Greetings,
I have GPS collar data containing 1387 points.
Each point is time/date stamped.
The feature class is sorted by date.
I would like a tool that simply starts at [Object_ID] = 1 and creates a line through [Object_ID] = 1387....essentially a sequential path.
All the tools I've tried (ArcToolbox: Points to Line), (GME: convert.linestopoints), (ETGeowizards: Point to Polyline) error out.
They want a field containing a shared value for multiple points, because you can't draw a line with one point.
It seems like it should be fairly easy for a tool to work sequentially through a sequence of points and output a line with one less record than the total number of input points.
Has anyone perfected a process for handling these type of data in the past.
I am slightly embarrassed that I am having this much difficulty with a seemingly simple task.
I'm sure I am missing something obvious.
Any help would be greatly appreciated.
Morgan
