I realized, that I ve probably misinterpreted my situation... I m attaching PScreen of my model in the thumbnail... It makes a query table from polygon cities and table of surnames with the same "City_ID" field (related together by that field). Then I dissolve this layer by counties, adding the total sum of occurences by county (by setting parametr "Statistic field" and SUM type)... And I need THIS number (lets call it total number of surnames), to be put into a new field, as a constant. I would then type "calculate field" formula like: [stats]=[Sum_of_all_occurences_by_county]/[total_number_of_surnames] OR, I think, it could be also managed by setting that number into a variable, but dont know how to do that... (=how can I set a variable as a constant, that is a SUM of a field from another table from the model? )
Thanks 4 answer, JOHN
