How do I use/edit a KMZ in Arcmap?
15873
6
04-12-2016 08:39 AM
DavidStafford
I have kmz's that I would like to overlay in Arcmap for comparison to our data but I don't want to convert it.
DarrenWiens2
There is no way to view KMZ in ArcMap without converting it.
ChrisSmith7
Honored Contributor
I think you can natively with ArcGIS Data Interoperability (ArcGIS Data Interoperability | Overview).
DarrenWiens2
You might be right, Chris. The supported formats lists "OpenGIS KML Encoding Standard" although I don't know if that includes all KML, or any KMZ.
AdrianWelsh
MVP Honored Contributor
David,
Like Darren said, you will need to convert it.
Use this tool:
KML To Layer—Help | ArcGIS for Desktop
Make edits, then use the opposite tool to change it back:
Layer To KML—Help | ArcGIS for Desktop
DanPatterson_Retired
kmz files are zipped kml files ... some backgrounders that are useful
Can I convert a kmz file to kml? - Geographic Information Systems Stack Exchange
provides some help and with the aid of python  modules:
  • glob xml.dom and zipfile modules
one can even process things directly, for example
Calculate distance from .kmz files « Python recipes « ActiveState Code
And there are many other examples out there.
well...
Script:     kmz_kml.py
Author:
[email protected]
References: many
Purpose: convert kmz to kml base script
import zipfile
from xml.dom import minidom
def kmz_to_kml(fname):
    """save kmz to kml"""
    zf = zipfile.ZipFile(fname,'r')
    for fn in zf.namelist():
        if fn.endswith('.kml'):
            content = zf.read(fn)
            xmldoc = minidom.parseString(content)
            out_name = (fname.replace(".kmz",".kml")).replace("\\","/")
            out = open(out_name,'w')
            out.writelines(xmldoc.toxml())
            out.close()
        else:
            print("no kml file")
if __name__ == "__main__":
    fname = r"Your_folder_here\GIS_central.kmz"
    kmz_to_kml(fname)
found it.  which could obviously be cleverly modified for batch production
