How do I export a feature class and its relationship or relate?
5762
02-10-2015 01:38 PM
MeredithRose
I am trying to export a feature class that has a relationship class with another feature class into excel. I need to have a one to many relationship between the two classes, so I think a relationship class is best, but should I relate them instead? My end goal is to have a worksheet of all of the attributes from one class and their linked parts in that are in another class.
MuratKarahan
If you need to export to a single excel sheet, first Join your tables in ArcMap and try export joined table.
help for join
MeredithRose
I cannot use a join because all of the attributes from one feature class that are associated with another attribute from another feature class will not appear, only the first one will.
XanderBakker
Esri Esteemed Contributor
Ifin the featureclass with the "many" features you join the features that do not  repeat, you should obtain the many features enriched with the other feature attributes.
