How calculate polygon dimensions
6457
8
08-18-2014 11:09 PM
NajdALHanahnah
Dear All
There is a way to calculate polygon dimensions (Side) , if i ma working on ArcObject (Java or .NET) any suggestions  ...
especially with complex polygon
Thanks
DanPatterson_Retired
I think the term is "perimeter" that you are looking for.  Did you do a search using    arcobjects perimeter  first?
NajdALHanahnah
Dear Mr.Dan
I am not looking for perimeter  i am looking for dimensions for each side ...
see what i meant >>>
nicogis
you can see code in this link : IPolygon4.ExteriorRingBag Property (ArcObjects .NET 10 SDK)
in this code when you loop on points you can get distance from point(i) to point(i+1) ...
nicogis
... if your polygons are composed from only lines ...
RiyasDeen
Below my suggestion, never implemented this scenario personally before just a possible solution
  • Cast your polygon to ISegmentCollection
  • Iterate through each segment
  • Use ReturnTurnDirection ArcObjects 10 .NET SDK Help‌ on your segments
  • If No Turn returned ArcObjects 10 .NET SDK Help then sum your segment length
  • Whenever there is a turn break your summation and restart
  • At the end you loop you would have got your dimensions.
NajdALHanahnah
Thanks Riyas for your post ,  i saw what you put and really interesting idea , but how i can do that in coding level , if
you have any idea plz help me ...thanks
RiyasDeen
Hi Najd,
Try below code.
Note: Even if there is a suttle change in direction between segments (i.e. not exactly 180 degree), it'll be treated as change and gets counted as different section.
Do post back if this worked.
                        ISegmentCollection segments = (ISegmentCollection)lta.Shape;
                        List<double> dimensions = new List<double>();
                        if (segments != null)
                            double length = 0;
                            for (int idx = 0; idx < segments.SegmentCount; idx++)
                                ISegment currentSegemnt = segments.get_Segment(idx);
                                if (idx + 1 < segments.SegmentCount)
                                    ISegment otherSegment = segments.get_Segment(idx + 1);
                                    if (currentSegemnt.ReturnTurnDirection(otherSegment) != 1)
                                        dimensions.Add(length);
                                        length = 0;
                                else
NajdALHanahnah
Hi Riyas
Thanks for your post , really appropriate that m, let me test it today and i will give you the feedback ...
thanks
