help using ModelBuilder
1274
07-12-2012 09:48 AM
MargaretMaginnis
I'm just learning to automate processes in Modelbuilder.  I'm a GIS analyst with a property valuation department in a large county in the midwest. We're working on a long-term project that's going to involve many complex steps across multiple departments. To keep track and efficiently make the changes that will be needed on my part, I want to use Modelbuilder.  The project involves creating 157 different maps of market areas within our county.  The goal is to establish more realistic areas for mass-property valuation.  Each map needs several new layers; ie, submarket boundaries, neighborhoods within each submarket,  residential parcel polygons, and parcel points of same -and symbology for each layer. I've created the base files and the symbologies for each layer, and have built a successful model that works through each process I need.  However, once the model has run, the new layers don't show up in my map. Or, if they do, they don't have the symbology and I have to manually apply it for each layer, each map.  The files are actually created and saved to a geodatabase which I can access through arc catalog.  (My model will include the creation of a new gdb for each submarket).  I think I'm missing a very fundamental step to get the files to show up in the maps.  if anyone can help me, I can give you more details as to how I'm approaching this if needed.  Thanks.
SolomonPulapkura
Right click on an output (usually represented by the oval shape) and check 'Add To Display' and then run the model. See if this works.
