GP: Reclassify
2591
11-09-2009 10:24 AM
KevinKuhn
Hi all,
Has anyone used Reclassify on a 64bit, Win7 machine?  I am getting a very funky result.
I'm attempting to classify a raster 32bit, float (ranges from .02... to 7.4...)
to a 2 class integer.  The GP finishes, but I end up with 9 classes and values that range from 0 - 1,018,292,762.   not exactly what I was after.
EDIT: after further inspection, the majority (or all) of the ranged values seemed to classify correctly, but there seems to be a large number of extraneous values added somewhere in the raster.
I performed this same task many times on my 9.3 machine with the same data and worked just fine.
any help would be appreciated.
thanks,
Kevin
KevinKuhn
This might be inconsequential, but I find it odd that in the general forum the little open letter graphic shows posts not yet read, and a sealed purple envelope for posts that have been visited (and read).  just a comment.
KevinKuhn
anyone have any ideas ? I've tried subsequent rasters and the same keeps happening... am I missing something basic?
UPDATE:  after further tests, I get the desired results if I check the box for "Change missing values to NoData" ... apparently the input raster has null value as= "-3.40282346639e+038"
