Geoprocessing Tool prevents printing in Python
2083
6
04-27-2010 10:57 AM
JoeHeggenstaller
When using geoprocessing tools in a Python (2.5) script it appears to be preventing the script from outputting any further "print" command text to the screen. I am using various gp tools and they all appear to exhibit the same behavior. I use python "write" commands to write script processing progress into a text log, which is still working correctly. An example would be where I'm using the gp.FeatureClassToShapefile_conversion tool to export shapefiles from a geodatabase to a folder. If I comment out the gp tool the While loop proceeds perfectly and will print to the screen and write to the log. Here is a snippet of the code (it is properly indented, but won't display properly in this post):
# Sample Variables
New_Geo_GDB = "\\\\c:\\test\\ blahblah.gdb
try:
print "Start exporting shapefiles from feature classes of " + New_Geo_GDB + " " + time.strftime("%H:%M:%S", time.localtime())
writeLog.write('Start exporting shapefiles from feature classes of ' + New_Geo_GDB + ' ' + time.strftime("%H:%M:%S", time.localtime()) + ' \n')
# SET WORKSPACE TO THE GEODATABASE
gp.Workspace = New_Geo_GDB
# CREATE OBJECT TO HOLD GEODATABASE OBJECTS
desc = gp.Describe(New_Geo_GDB)
# CREATE CHILDREN VARIABLE TO HOLD LIST OF FEATURE CLASS NAMES
children = desc.Children
# RESET THE LIST TO THE BEGINNING
children.Reset()
# MOVE TO THE FIRST OBJECT IN THE LIST
child = children.Next()
# LOOP THORUGH THE CHILD OBJECTS WHILE THEY EXIST
while child:
  # CREATE VARIABLE TO STORE THE GEODATABASE AND THE FEATURE CLASS NAME TO EXPORT
  InGeo_Dataset = New_Geo_GDB + "\\" + child.Name
  # PRINT AND WRITE TO THE LOG
  print "Exporting to shapefile folder: " + child.Name
  writeLog.write('Exporting to shapefile folder: ' + child.Name + ' \n')
  # GEOPROCESSING OBJECT TO EXPORT FEATURE CLASS TO SHAPEFILE
  gp.FeatureClassToShapefile_conversion(InGeo_Dataset, shapeDir)
               # MOVE TO THE NEXT FEATURE CLASS
print "Finished exporting feature classes to shapefiles: " + time.strftime("%H:%M:%S", time.localtime())
print " "
writeLog.write('Finished exporting feature classes to shapefiles: ' + time.strftime("%H:%M:%S", time.localtime()) + ' \n')
writeLog.write('  \n')
except:
print "! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! "
print "Export shapefiles failed!"
print gp.GetMessages(2)
writeLog.write('! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! !  \n')
writeLog.write('Export shapefiles failed! \n')
writeLog.write(gp.GetMessages(2) + ' \n')
JamesGonsoski
http://resources.arcgis.com/content/nimbus-bug?bugID=TklNMDQwNTI4
Then wait patiently for version 10.0.
Jim G.
MN Dept of Agriculture
JoeHeggenstaller
Thanks Jim. I looked all over the old & new forums and didn't find that one.
RDHarles
This also (randomly) happens with the gp.FeatureClassToGeodatabase() tool.
JoeHeggenstaller
I noticed that also, but was trying to keep my example simple. Thanks.
FrankPerks
You can overload the sys streams after esri plays with them, to restore print functionality. So you can have a happy print.
import arcgisscripting
import sys
class GPPrint(object):
        Use enable or disable print please =)
    def __init__(self, gp, is_stderr = False):
            Initializer
        self.gp = gp
        self.is_stderr = is_stderr
    def __del__(self):
        self.gp = None
    def write(self, msg):
        if msg == '\n':
            return
        if self.gp:
            if not self.is_stderr:
                self.gp.addmessage(msg)
            else:
                self.gp.adderror(msg)
    def flush(self):
        pass
    def writelines(self, msg):
        self.write('\n'.join(msg))
    def close(self):
        pass
gp = arcgisscripting.create()
sys.stderr = GPPrint(gp, True)
sys.stdout = GPPrint(gp, False)
print "Hi"
print "Hello normally this would not work but i am =)"
# Now lets say we want to restore the streams...
sys.stderr = sys.__stderr__
sys.stdout = sys.__stdout__
However i strongly suggest you look into the logging module for working with large projects.
JasonScheirer
Esri Alum
I second the use of the Python logging module for any large/long-running tool. It's fairly trivial to add logging handlers that post to gp.addMessage and gp.addError when the severity level of a logging message is high enough, and you can log less important messages to log files for later inspection, etc.
