Geoprocessing a Database View
954
11-01-2012 05:19 AM
MortenHjelmsmark
Thanks for the CreateDatabaseView_management tool, creating sde view's is now quite easy.
But how can I use the view in my script tools?
If I work in ArcMAP I'm asked to identify the OID column, which then enables further use.
How do I avoid getting the ERROR 000339 (view has no OID column) in my script tool? I need to make a selectbylocation..
My tool workes in 10 with view's created with the sdetable create_view command.
Is there a solution or do I have to go back to SDE commands?
