Geocode unmatched addresses best workflow?
1067
03-16-2023 06:37 AM
jzcgis
Every month a get a new csv file with addresses to geocode. This file is 80% the same addresses each month so I created a locator to not waste credits. My workflow has been geocode with my locator first then to select the "U" and export them into a table then geocode these with the world geocoder. Then take these and append back together to the results of the local geocoder. Then These new addresses get added to the local geocoder. First of all, is this the best workflow for this? Is there an easier way to deal with this? Is there more documentation on this? I am sure I am not the only one that has had this issue. My goal has been to automate this in model builder or python but I wanted to see if there was more information about it.
Tags (1)
ShanaBritt
@jzcgis In the Rematch Addresses pane you have the option to select addresses that are unmatched and select a different locator to geocode the selected unmatched records w/o having to export the selected records to a new file and then append the results back.
https://pro.arcgis.com/en/pro-app/latest/help/data/geocoding/rematch-locations-converted-from-a-tabl...
