Fishnet Batch
1472
09-29-2011 03:31 PM
AdamWoodard
Hey,
I am looking for a way to batch out grid generation(fishnet) from Landsat imagery on hundreds of files.
         1. First is there a way to batch it out, I only need a 4x4 grid to overlay the imagery
         2. If possible, can the grid be of the active area of the imagery, landsat imagery has a square background of ???No Data???, this is what the grid usually reads from
Adam
markdenil
Interesting problem.
You could start by converting the image to a polygon feature class. (Raster to Polygon)
(Maybe reclass the image to a binary raster (image = 1, nodata = nodata) first.)
This should give you a polygon of the image area: a tilted rectangle.
Run Feature Veticies To Point: this gives you corner points (plus some more, maybe)
Run Add XY Coordinates on the point class: now the points have recorded coordinates
Use a Search Cursor to find the left-most and top-most points, and grab their coordinates.
Now you want the distance between the points.
If you have ArcInfo, make a layer of the left point, and a layer of the top point,
and run Point Distance. Get the distance from the resulting table
If you DON'T:  you can use trig
OR you can generate a line between the points and get the length.... whatever.
divide the distance by 4 (for your 4 x 4 grid).
In Create Fishnet:
Fishnet Origin Coordinate = the left point
Y-Axis coordinate = the top point
Cell Size Width (and Height) distance between the points divided by 4
Number of Rows (and Cols) 4
Maybe not perfect, but its a place to start...
Oh, yes, do it in Python.... Loop through the images and clean up the intermediate files as you go.
M.Denil
NobbirAhmed
Esri Alum
Use Create Fishnet tool (Data Management Tools > Feature Class toolset). Use the imagery data as the template extent.
Run once. From Results tab copy the result as Python snippet.
Then, use a python for loop to run in a batch.
markdenil
Would that not give a lattice that matches the image extent, rather than the image data area?
The need was for a grid that did not include the no data area.
I agree that the whole thing is very much simplier if the grid just has to match an orthoganal rectangle.
M.Denil
